May be I am not understanding what you are trying to explain.
As the switched wire connects the 230V from the switch to the lamp, to supply the L to the Lamp to light it, and then this switched L is fed to the fan. So if this switched wire connects/shorts to the permanent L in the fan, then surely that permanent L connects through the switched L to the lamp supplying it with 230V. The Lamp already has a permanent N, and now has a L.
I am sure if the Permanent L and Switched L were connected/shorted any where then the lamp would stay on.
You are correct, hence my previous edit.
