See another post someweher else, problem is the network transformers can't reverse feed the grid, ..........
See another post someweher else, problem is the network transformers can't reverse feed the grid, so all energy has to be 'consumed' locally, hence the problems, that coupled with lots of microgen gently pushing up the voltage causes problems - a lot of local transformers are already on the 1st tap, to now go and change the upstream one, would then mean retapping all the local ones ....... hence the big headaches..
Seems like press only get half the story - the bit they want us to hear!
