The 'thinking cap'. For deciding which tool to use, where to use it, when to use it, how to use it and throwing the bloody thing away when you find it's useless.
do it right then. first wrap a bit of bog roll around the cut, then tape it on. (make sure the bog roll is fresh and unused though)
this......
Yes. it soaks up the blood better than just tape, and I'm always afraid that when I peel the tape off it'll bring the scab off with it and the wound will open up again.
Podger (Anchor setting tool) and draw tape (fish/snake) as well as a good bright torch, and WD40 for threading conduit instead of Tallow, use to thread then use to clean after finished threading and filing......
I havent had a drift (setting tool) for ages, I usually use a 7mm drill bit. Agree with the non fish tale, the steel ones are crap. As for conduit, by far the best threading compound to use is Texamol. It is brilliant.
i keep saying im going to wear gloves for every job every day, but always end up taking them off , and wallllla cut myself....
i say gloves.......... which of course you can tape up and keep to dust proof..
is ther a good tool out there other than a coat hanger for when the get shoved up ceiling...
If it works don't fix it!
Might start selling bent coat hangers on Ebay, wrap a bit of tri rated cable on one end and stick a fancy label on, titled "iCable Recoverer"
£9.99
RogertheBodger,
ipf,
