S
Skyba
Hi,
Bare with me on this what feels like a very stupid question but I'm just getting to the end of my apprenticeship and I'm going to be looking at trying to do some private work soon as times are hard and I've had to go self employed as an improver to complete my apprenticeship.
Up to now I've mainly worked on heavy industrial new builds or council domestic work where everything is surface mounted.
I'm just wondering what do people use or do when fixing sockets to an existing cavity wall, would you find the stud and cut your box out there and then notch the stud and fix a metal back box, I've seen this suggestion before but I'm sure in the regs it says that notching joists is a no no these days.
Or would you use a fast fix/dry lining box, I've seen these and I've used them before on jobs when the plasterers jump the gun and board up before we've had chance to fix all our noggins and boxes. The only thing is I've heard these are on for light switches but they apparently come lose after while when used for socket outlets.
Sorry if this seems like a silly question but these are the silly things that people these days are not being shown because of the lack of work and being stuck in such a narrow field of work due to the climate and not getting experience in all types of work.
Thanks for any help
if the wall is masonry and dry lined, i use metal boxes screwed to the blockwork. if it's a stud wall, then dry lining boxes are fine to use.
edit: if you get in before the boards are put up, fit horizontal noggins recessed about 22mm and fit metal 25mm boxes to the noggins.
Existing stud walls then most of the time use the cavity boxes, but if the wall is new then always use metal box with a noggin fixed in place.
The cavity boxes won't come loose, they can be used for sockets, thats what they make the 2 gang versions for. Only draw back when using the cavity boxes is if they are fitted before the plastering is done, you don't have much adjustment on them.
i now use Click fire rated cavity boxes they are metal with spring loaded lugs a tad more expensive than the standards but worth the little extra
These are the boxes I've been using on the job I'm on at the moment building a new hospital and they seem good but obviously I'be never seen how the fair over an extended period.
