i dont see how a piece of metal rail and a plastic box with a "name" stamped on it can affect the operation of RCBO and MCB...!
there is no modification to bus bars and or enclosure so its no different t fitting bosch discs and pads to your nissan car rather than a set of manufacturer supplied parts..!
I agree with you, but tell that to the manufacturers and they will probably come back with a host of (probably wholly unjustified) reasons. At the end of the day it almost certainly nullifies any warranties/guarantees that apply.
It would be interesting to know what would happen in a catastrophic failure that caused untold damage, if it came to light that the installation had been installed against manufacturers guidelines, and therefore not to the BGB. No doubt any insurance the installer had would be null and void. Even if the fault was not caused by the differing boards/mcbs, you know they would use that as an excuse.
:rolleyes2:
Just to be devil's advocate...
I thought the 2nd sentence in 134.1.1 meant mixing different boards and breakers was now frowned upon?
:earmuffs:
Can't see that using this combo will ever be frowned upon.
ECD don't even make or produce a consumer unit body so they can't have an issue.
They sell one yes, and i'm sure its an MK unit anyhow
Yes it is MK.
Can't see it either!
Eaton/MEM for me, or Hager for domestic work. No one has mentioned Contactum yet? If I'm on a tight budget I'll fit it. I like the colour coded MCBs :D
I use Contactum from time to time, can't fault them at all really. 99% sure they're now rebranded as British General.
Hager are good but as they're French I'll try and keep my business in country. Also use MK which again I can't fault but mostly fit wylex (not by choice) and can't think of any redeeming factors for them
For domestics I like crabtree or wylex, they're both produce by schnieder now. For heavy commercial industrial mem or merlin g. I don't rate mk in any sernario
Hager are good too. Like all the different components they do that fit in. Relays, timers, etc..
Yes it is MK.
Are they MK badged or just identical but without the branding?
Whilst I can see the appeal in buying ECD RCBOs given how much cheaper they are, why on earth would anyone buy some of their unbranded MCBs when they are dearer than the branded ones? Even their 10ka ones are dearer than most.
I wouldn't, but as every time i've used them is a domestic situation, every circuit has required 30mA protection so an MCB wouldn't come into it.
the british general boards are good value for money....and theres more room in em for RCBOs than with..lets say electrium stuff (wylex, volex, steeple etc)....
Sorry if I'm being a bit slow, but you're saying you just buy their RCBOs?
Have you had any dud ones yet or are you happy with the quality?
It would certainly be easier to convince customers to go for an RCBO only setup using their prices, at the moment £25 per circuit is a bit too much for most people.
Cheers
my last 5 customers have been RCBO's from ECD!!
not had a dud one yet! i keep a ready stock of them now due to amount im using so if i get a faulty one it will just get sent back..!
apparently the ECD rcbo's are tooled on a an EX MK pattent that was bought hench why they look similar and fit the MK empty enclosures perfectly! (they also fit schnieder as well)
if you get the empty box from ECD you get a ECD isolator thrown in with price!! :)
my Dual RCD prices are only slightly cheaper then my full RCBO install prices now!! :)
Cheers
Yes, just the RCBOs. Main switch then all RCBOs. I don't get many domestic situations where just an MCB is permissible you see.
Only had one issue, and that was a damaged RCBO caused by the courier and it was replace with no issues.
They're the same as many other cheaper brands out there
Rick b,
Deservices,
