A
abneyelec
Hi,
My brother complained that he had got a "mild" electric shock from the shower control and also from the heated towel rail. I went to his house today and tested the earth loop at the shower, the towel rail, the bath taps, literally every bit of exposed metal in the bathroom and it all tested fine, less than an ohm. I also checked to see if there was any voltage (difference in potential) between the metalwork and neutral and also to the earth on the sockets, again no problem here. I then cross bonded the pipework in the garage where all 5 pipes run next to each other.
He has rung tonight and said that he got a shock again, but only when the shower was "on" by the way it isn't an electric shower and there is no shower pump. I have to admit that I am a bit stuck with this one and would like some advice.
Cheers
Paul
Has this recently started?
Has any work been done in the house plumbing or electrics?
Has he changed the flooring in the area where the shower is or bedroom or any area leading to the shower?
Is the shower enclosed by a curtain?
Has he changed his type / style of clothing recently?
How is the water heated, gas boiler, combi gas or immersion?
Have you thought of testing with the shower running?
Had a similar fault recently and after plenty of investigation found the inside of the stud wall was live. The wall was made with foil backed plasterboard and when the bathroom was built a plasterboard fixing screw went through the plasterboard foil and into the live supply wire to the main feed. Strange thing was that this bathroom was installed and tiled 10 years ago.
In this situation get a wander lead or extension plug it in to the nearest socket then plug in a R1-R2 test plug into it and make sure it has a good earth the make sure the socket is switched off so you now have a good reference point for your test meter . Then test between the lead and the towel rail with shower on and off and yep no need to strip off to do this lol
I heard that you DO have to strip off to get proper readings. Don't you also have to insert a 17th Ed chicken feather into your anoose for the test to be reliable?
