diego_maradona
Hi all,
Apologies if this has been covered multiple times before but just wanted some help. I'm not an electrician, but am getting some work done in my house. Part of it is to run electricity to my back annexe. Now my builder and his electrician are busy right now but have asked me to buy a consumer unit in preparation for them.
The guy I bought the house from already built the annexe at the back with multiple double sockets and lighting all installed, just no electricity running to it. So I have bought a 6mm 3 core shielded armour cable. Now I have been recommended this unit to buy:
[h=1]Wylex 2-Way Garage Unit 63A 30mA RCD[/h]
Only thing is, it would seem the guy had 2 circuits for the power circuits and a 1.5mm t&e for the lights. I've attached a picture of the cables that need connecting to the new garage consumer unit. Would someone be able to recommend a good CU to buy?
Hi and welcome to the forum. Unfortunately because your a new poster your picture.attachment will not attached so it's difficult to gauge what actually your trying to achieve.
When you say "annexe" are you talking about an extension that is attached to your existing house?
If so I have to ask why can wasn't the circuit cables for this "annexe" back to your existing board that does the whole house?
Your "Garage 2 way board" you say incorporates a 63amp RCD, does your existing board also have RCD protection?
The "two socket circuits" cables could be a ring or two radials, your electrician should confirm this and also tell you what size MCB's to buy. The above 2 way cu is fine if you have 2 circuits.
Just a point, Is there a rcd in the house feeding your 6mm? Again this is something that your electrician needs to look at in the design stage.
its very difficult to make such a recommendation without having more information and seeing the actual situation first hand.
If I was "your" electrician I wouldn't be asking you to buy a CU without specifically telling you which one.
Thanks fellas. I can't post the images from my phone just yet, I'll try upload the original image and a picture of my main consumer unit in my home later.
The annexe is just a large granny flat at the back of the garden. I bought the house unaware he hadn't actually wired it up! Will get back to you all soon!
I won't be doing the work. My builder an his team are a little stretched. I like to always seek advice from others too before naively going ahead with a job so please excuse my naivety.
Here are the wires I am talking about. So 2 sets of 2.5mm t&e and 1 pair of 1.5mm t&e:
and this is my main consumer unit
Trust me fellas. I'm thinking the same as you, Lord knows what the previous guy was thinking. But this is what I have to work with. He put up absolutely loads of double sockets around the room. My immediate plans are just to use it as a gym, maybe hang up a tv. Future, I may turn it into a cinema room.
Don't stick your fingers in to the gap!
So help me here, you are thinking about buying a 2 way board and sticking how many cables into it??
Somebody recommended the Wylex box I posted before, but they didn't realise I had so many cables to shove into it! So my question to the experts is what do you think I should get?
diego_maradona,
Des 56,
