You have used an additional coulpe of cables that don't operate from either switch 1 or switch 2.
No, i'm afraid not.
Good effort.
No, it is not the correct way. The circuit must start/end from switches respectively. No external loop in lines or neutrals that link in and out.
I used the parallel-series combination myself and had the door slammed in my face ..............'lights at full brightness'
Another comment would be.....................perhaps the switches could be different phases???
in possition 2 lamp 3 is wired is series?
Hi Simpson,
I think in position 2, lamp 3 is actually short circuited, i.e. both poles of the bulb connect together through switch 1.
Short of going out and wiring something up in the garage, not sure if what I have drawn will work, but do not have any 2 gang 4 way switches lying around!
When your switch is in position 2, lamps 2 and 1 are on in series.
Keep trying though.
Nice effort.
You will find (depending on series or parallel) that either multiple lights will be illuminated when they shouldn't OR the bulbs are not at full brightness.
Genius.
You got it mate, i overlooked the use of the backwards fed light. Nicely done.
There is a second way, different to yours if you want a further challenge?
Hobsoni,
electric will,
