N
Norn Iron
Can somebody help me with pricing for new 20A double pole switch and single socket, also a double socket all this needs tracked into the wall and will be contained in steel conduit?
Length of cable, height of wall, how far from CU, type of socket, etc, etc, etc
If your an electrician then price per hour - if your a customer then get some quotes - pick the middle one
You need to be more descriptive. For eg: I presume this is a domestic dwelling? What kind of access do you have to area work (floorboards, furniture........etc), are the walls thick plaster or thin plaster with lots of engineering brick (admittedly, without chasing out and seeing for yourself this will usually come with experience)...........have you checked to see if earth bonding is in place?..........have you included fee for notifying council for installation of new circuit? Have you been to price the materials you require............is the consumer unit up to standard with RCD protection? the list may seem extensive............but you need to be accurate with your assessment when you go to look at a job.
Hence I no longer work for myself but for a firm!! lol
Everything you should be asking yourself................as well as performing the 'actual' said works.
