S
sparkygg
This is my first post and hoping someone can help?
Just wired an external combi oil boiler. I ran a 10mm bond from CU to the incoming pipes which are all 22mm and 28mm copper. They come through the wall from outside and I have put an earth bonding clamp on each pipe and looped the bond between them all. Now I am not sure if I should have run the bond out to the oil line entering the boiler? It comes through the ground for 20m or so and pops up just beside the boiler which is mounted on a paving slab plinth. The oil pipe doesn't enter the building and as i said any metal pipes which do are now bonded. The incoming water is in blue polypipe and is bonded where it turns to copper further into the installation. What should I have bonded? I am confused!
Any guidance would be appreciated.
