G
gerry.slater65@
Hello all.
Doing a favour for a mate. He wants an "industrial" look his new wiring. He wants metal conduit and chunky surface fittings on bare brick walls.
I can't remember the last time that I installed metal conduit.
I haven't got a bender and no taps and die's.
He doesn't mind if it all goes at right angles from box to box.
Is there an easier way or product that I can use without threading everything?
I would appreciate any ideas or advice on this.
As it is a favour, I would like to get it done as quicky as is possible.
Many thanks in advance.
Gerry
Boxes everyywhere will look - I been warned for swearing - no so good. Perfect chance to practice. Hire the gear.
Galv conduit on brick looks good! I've done some in warehouse to studio converts, and seen heaps in the states. Stylish.
which planet is your mate from? if he insists, you can get push fit boxes for galv. conduit.
They used to do a "knock on" couplers and box for conduits. i have used them in the past
I used them where they cut a lift in through a concrete floor and cut through around 6 conduits which were the earthing for the circuits
Ask your supplier or try google
Use plastic and spray it may be an option, not aware of any but it would not surprise me if you can actually but it in a silver finish
Gerry, advertise for an experienced conduit fitter and you do the wiring.
You (and the customer) will get a good job done & you can look & learn. Win all round!
i dont know what sort of finish it would give but im with SYKRAPS.. sounds ull b more comfartable with plastic cond then spray it..
Sprayed PVC would look sh!t. Especially when it starts getting worn.
I've yet to find a decent silver spray.
Will the conduit be the earth though? he may need it threaded and done properly, time to buy a bender and some stocks and dies.
