Head hurts now!
You only need the one switch after any FCU
But the whole idea is to have a nice little seperate switch like the OP wants to switch on the light even if the PIR says 'No', without having to use the faffy overide function dial on the PIR.
Hi fella, even doing the Job your way your only need one switch after the spur, anyhow not trying to be anything other than chatty here, please don't feel offended at all, it is just a discussion, basically no need for the first switch you showed on the drawing your way, if it was me I would just take a pair to the light and a pair from the light to a switch, thats just me.
Perm live to your common, then from common to L on your light, switch live to L1 on the light and neutral blocked inside your switch.
Switch off then light operates via PIR an switch on light is over rided until switched off.
4 core flex to the light.
None taken :smile5:..... Draw me a diagram :wink_smile:
By the way I'm working in stroud at the moment, well not now haha, but have been during the week.
You're right, thats so simple! Apart from my diagram being overcomplicated its also completely wrong!! I enjoyed drawing it though :smile5:.... but next time I'll draw one on my day off and without a pint of guiness. I'm going to bed embarrased but not disheartened :cry_smile:
Good place to work, nice people and nice coffee shops...
ample current,
RyanCheetham,
