You're missing something. Properley rated MCBs for a start. A qualified electrician aswell possibly? Daz
On the continent it is normal to see immersions fed from plug top and lets face it we have the best plug top in the world so can understand the comments on this tread. But saying that it would not be the way I would wire it.
until about 12 months ago my own immersion heater was wired via a plug/socket. Worked fine ;) but then it wasn't fused by a 6A MCB... :lol:
well, having seen plugs welded into sockets on just 2kW kettles, either their calculations are wrong, or sockets compliant with BS1362 just ain't.
Not to mention the fact that DIY Charlies will save a few pence by buying un switched sockets and repeatedly drag the plug out when it is under load and this definitely wont do the plug any good. Again it may be acceptable under the "Regs" but how many times do i say that common sense takes precedence over the regs.
Cheers...........Howard
This one isn't DIY Charlie, its DIY KRISH537
Thanks to everyone who gave good info, there's a lot of sound advice been given.
I'm closing the thread at the request of the OP.
