With a little experience, you soon decide that placing lables on them is a good idea.
Especially if you plug a 12V transformer into an external Hard Drive then discover that the polarity is reversed, or that it's only meant to have 5.5V.
Well, I looked and on my laptop charger box it says "20V", but I wasn't asking about that. The point is that I don't have to plug that huge box itself to the outlet.
I think you need to get a more modern phone - the chargers I have are all no bigger than a standard plug :lol:
The cell phone was just an example :) I do have a modern phone and thankfully they solved that problem, however it's some of the other things that still have those enormous boxes and I find it annoying if I am in a place that doesn't have many outlets (or if they are poorly placed) and I have to connect more than 1 one of those boxes to the same outlet, which is impossible sometimes.
well dont start with those 3 way outlets...their bad news are them love...
The way china see's it is its cheaper for you to fit a few sockets at correct height as oppose to throwing multi-millions on a charger design so you don't get stressed.
Sometimes I'm at a place where the socket is so close to something like a wall or the floor that I can only plug in just 1 box and nothing else (even though there are 2 outlets). And then wait until it's charged before I can do anything else.
Oh well, I guess there's nothing that can be done about it. :(
Thanks for replying, everyone.
OK, I looked around on Wikipedia and found that I wasn't the only one bothered by this problem.
While useful for many purposes, some external AC adapters have attracted criticism. Problems with this type of power supply include, but are not limited to:
1. Size — Power supplies which plug into the mains directly without using a plug on a cable (true wall warts) are bulkier than bare plugs; sometimes they are too large to plug into power sockets with restricted space, or into adjacent sockets on power strips.
2. Weight — Some AC adapters can be heavy, exerting excess weight on the power socket (this depends on the socket design of the country in question). Some external power supplies are "power bricks" (also known as "line lumps") having a short AC cord so they can lie on the floor, thus relieving strain, at the expense of clutter. Other wall-hanging types are made long and thin, minimizing the leverage of their weight vector that pulls the plug out, at the expense of exacerbating the size problem. The weight for equipment that must be carried (e.g., for traveling) is not a disadvantage of external supplies, as the alternative is an equally heavy internal supply; in many cases a single universal supply can replace several proprietary ones.
It also talks about Universal power adapters, but that looks really confusing and potentially dangerous.
I guess I just have to deal with it...
Sometimes there are complicated electronics in the "box" which would make it too bulky to fit dirrectly in to the outlet (socket) so they give you a lead that plugs in then feeds the box (transformer) then a lead to the device which you want to charge.
Why do you worry about it though? if you can plug your device in to the outlet via a box and it all works sometimes it's best just to accept it for what it is. I know that sometimes things can take up a lot of space but is it really that important?
If it all works then don't worry about the mechanics of how it does what it does.:)
Don't you sometimes wish you hadn't got involved ?? ;)
my charger for this phone don't cause any problems. it's a 10kVA genny.
I have to admit this is a big concern for me Susanne, I often lie awake at night worrying about it. Sometimes I cry myself to sleep thinking about how I can only fit one box thing in the socket outlet. I am on your side. :)
So, why can't they all be something similar to laptop chargers?
Because they are 'switchers' or SMPs - google that one and see what pops up.
Most TX equivalents are small electronic devices that are portable and provide the correct DC output for particular electronic appliances. They are also cheap to run, don't produce heat and weigh next to nothing.
See Telectrix for an in depth answer......... :)
OK. so i'll try for that in depth answer. this lets you take pics with your iphone down to a depth of 100ft.
i'mm struggling to find an underwater charger , though.
well, you asked for an in depth answer.
American chargers are smaller than the ones here.......why doesn't the original poster just use an extension to free up space as well as getting the extra few plug spaces from that.... the mobile/cellphone charger is designed to step down straight away at the wall outlet without any live mains flex in between.....for safer use as well as cheapness of manufacture.....they are made as cheaply as possible, just a few cheap components ( phone chargers are made for about £2.00 /$3.00)
Hi Susanne, may I ask a question of you,do you have a partner? because I am sure if you gave it a little thought then between you you could find more interesting things to do than worry about the size of power supplies for phones and laptops.best wishes and compliments of the season Phil.
susanne,
tidyboiler,
