That,ll be a class 2 in line fan !!!!!!!!!! yes ? don't forget to bond it 10mm remember just incase the RCD FCU fails and you shower with a 2meter metal pole (dancer). only joking !
- - - Updated - - -
Hi, I don't understand ? Class 2 is class 2 ? All you guys preach is regs regs regs, apply common sense, I have had no professional electricians response to my question ? Only the usual assumption that you're a DIY's who's not in the 'sect'
and to be ridiculed.
Hi, can I ask if the fan was class 2 would you still be required to install the rcd fcu ? And what's the point ?
Just interested to know, thanks.
To be honest, an RCD FCU would not comply, as the requirement is to provide protection for the circuit, not just a part of the circuit or the equipment connected.
It doesn't matter whether the equipment connected is class II or class I, the Regulations still require RCD protection.
The only time RCD protection would not be required, would be for ELV or SELV circuits.
Funny how yesterday you were wanting to know about a SELV fan that an electrician has installed who has since died./QUOTE]
There is nothing funny about some ones death, and I did not say he installed it he wired it!
Hi, being a diy'r i don't have any regs books or a bible! I assume, the 230v supply which supplies the ELV OR SELV must be outwith the bathroom ?
Thank you for a professional and curtis response .
Yes that's right, but where are you fitting the transformer? Bear in mind that any cables buried within 50mm plaster depth of the wall have to be rcd protected also.
