O
Octopus
The only reason somebody would use 2 x T&E rather than 3 core is they are using knocked off kit from site on a homer.
2 x T&E - very bad practice IMHO
.....on a homer.
i was went to a job where all ring mains where wired in 3core +earth, they used earth for all back boxes and the 3 cores for the socket terminals
i don't understand. Could you please explain again?i connect the wiring within the pattress extension boxes underneath the smokes.
this is my last , and possibly only , sensible post of the nite.![]()
Agreed stuuk!! There is nothing wrong with the way it's been wired as long as all cores are connected,
I.e live neutral earth from one, ic from brown core of 2nd t&e and then earth the blue core and the remaining earth,
theres people out there that would wire it in twin and use the earth as the ic, so using two twins with all cores connected is perfectly acceptable practice!
Some people need to stop thinking they're better than others, I am a qualified spark (17th) and I say to my apprentice, I'd rather you make my ears bleed with questions than you be in any doubt over anything you do in work, just help the poor sod, and get a grip, the poor lad wants advice, not an earful!!
That's totally ludicrous.....could he not be bothered to go to the wholesaler? It's like me saying, "Ahhh, I've run out of smokes, can't be bothered to go to the shop, I'll just smoke this teabag instead.".
Screwfix tea isn't the best either.Screwfix open on a Sunday ?
Don't believe it for one moment
Screwfix smokes are cheap and nasty
