Don
Hi need advise on cable 25 meters run underground for additional consumer unit in garden outbuilding to acomodate 9Kw sauna heater 10kw water heater 3double sockets 6 down lights and 4 outside lights?Thanks in advance .
And how to consider the capacity ?what i can do is only wire cables but not connecting them .I was suggested Henley on main incoming 100amp then 25mm armoured cable. But know Consider capacity??
Look is not your business chancer or not I'm asking because half electricians I called to give me quate came with lots of bul...et you need that and you need that because law states this is how should be and at the end they want 1000 for two days work it's ripp off because I know basicsYet another chancer with not a clue what he's doing.
