thats what i thought but knowing what the litigation brigade would make of the case should the worst happen didnt want to leave myself open.
I think the solution is not fit the boxes but give the client a set of instructions about what type of bulbs can be fitted and get him to sign a copy as read and understood, 10pence worth of paper and ink against 150 quid off profit for the job
People still confusing fire rated downlights with the need to keep insulation away from the back of downlights.
The fire rating of downlights refers only to their ability to slow down the rate of fire progression through the light fitting..
The intumescent strip expands on contact with high temps and seals the hole to prevent further fire progression. They are to be fitted when penetrating an "existing" fire barrier with light fittings.
They are JUST as likely to overheat and cause a fire if you cover them with insulation.
Fitting fire rated downlights does not absolve you from sorting out the insulation above.
nick a few shopping baskets from tesco. place inverted over downlights. insulation on t6op of baskets.:punk:
edit: make sure to earth the baskets.
IMO its quite simple, if continuous insulation is a requirement then you have 3 options.....1) no down lights, 2) fit downlights which can be covered by insulation (NOT JUST FIRE RATED), 3) use the box/cover............option 2 would be quite expensive, so I would opt for option 3..however, sod the £9 metal boxes, just get some plaster board and cut it into sections so that it covers each downlight and screw it on cieling joists either side, creating a bridge for the insulation..hey presto sorted
dome a house recently where they put that insulation board 100mm thick in rafters, when putting downlights in here do you just bore right through it, which in turn breaks u values specified,
Dont think your suppose to, I believe your suppose to battern it out so its lifted off the light. But I'd just bore it out and make a nice little gap all around the light with a stanley cos I couldnt care less about the u value.but thats just me
Why can't you ad the cost of the boxes/hoods to the job? Fixed price? If so fit em, bite the bullet and sleep easy at night. Live and learn mate.
Waste of money, a sheet of plasterboard cost about £5, and you could probably make about 6 flat covers with it.....
If this was my own house, I'd probably do as you say.
But in this case I don't want to take any risk that I installed something that was not fit for purpose, e.g. in event of subsequent problem (like a fire).
At least buying a product approved for what I'm using it for means I only need to ensure it is installed per manufacturer's instructions and intended application.
Cant see there being any problems what so ever using plasterboard to bridge over downlights.........plasterboard is not flammable, it will keep the insulation off the downlights and provide the desired air gap around the light....... this would be no different (well not much) from say fixing the recessed downlights below the ceiling just like a surface mounted light.
What are you meant to do on a vaulted ceiling?
When ever i've fitted down lights in these (New build/extension i.e. new ceiling) i've told them to leave 300mm gaps the the celotex for the fittings.
This has now made the insulation non continuous ??
