Dont think your suppose to, I believe your suppose to battern it out so its lifted off the light. But I'd just bore it out and make a nice little gap all around the light with a stanley cos I couldnt care less about the u value.but thats just me
Why can't you ad the cost of the boxes/hoods to the job? Fixed price? If so fit em, bite the bullet and sleep easy at night. Live and learn mate.
Waste of money, a sheet of plasterboard cost about £5, and you could probably make about 6 flat covers with it.....
If this was my own house, I'd probably do as you say.
But in this case I don't want to take any risk that I installed something that was not fit for purpose, e.g. in event of subsequent problem (like a fire).
At least buying a product approved for what I'm using it for means I only need to ensure it is installed per manufacturer's instructions and intended application.
Cant see there being any problems what so ever using plasterboard to bridge over downlights.........plasterboard is not flammable, it will keep the insulation off the downlights and provide the desired air gap around the light....... this would be no different (well not much) from say fixing the recessed downlights below the ceiling just like a surface mounted light.
What are you meant to do on a vaulted ceiling?
When ever i've fitted down lights in these (New build/extension i.e. new ceiling) i've told them to leave 300mm gaps the the celotex for the fittings.
This has now made the insulation non continuous ??
air gap between this and planes
just because there LED it doesnt mean the fitting can be covered with insulation ! Some LED's can produce quite alot of heat still so if they are running warm im sure they wont last 5 mins :)
insulation boxes for downlighters
james beckford,
shocking_eg,
