T
Thomps
Went to see a job the other day where the client had an unusual setup. They have built a new extension to the house and are planning to relocate the kitchen to there and where the old kitchen was they are going to put the new bigger bathroom. I have been asked to replace the old wylex board and install the new electrics to the kitchen etc.
Now, the issue is that the fuse board and incomer are in the original kitchen which they are going to change into a bathroom. They don't seem keen on getting the supply and board moved so i am about to wash my hands of the job. They reckon a cupboard is enough to protect the electrics.
Surely this cannot be safe? I have never heard or seen anything like this before.
Well.... if its out of the zones and in a cupboard with a door, why not?
That said not something I'd want in the bathroom.
Could you move it so its high up well out of the way?
It may be out of the zones but i'd have to measure it. I'm just not happy with it being in a bathroom in general. If it is in a cupboard, probably a home-made wooden one, how can that ensure condensation will not affect electrics?
Insist they have an extractor fan with a humidstat??
Its just not cricket is it but if your not happy then dont do the job, it could turn out to be a lot of hassle...
Damp isn't as much as a problem as you think. My consumer unit was in my very rotten wooden porch, attached to a backboard that was so wet and rotten it tore like wet cardboard when moved, and when I took the lid off the Hager conusmer unit it has brown fungus growing in it and puddles of water, and everything still worked! Thankfully now I have a spanking new plastic porch for everything to live in.
Stroppy, you say damp isn't a problem...then you contradict yourself with the rest of the post lol. Damp is a problem and ure CU sounded hurrendous...glad you've got it fixed :D
As murdoch has rightly said, if its outside the zones then install it in the cupboard - not ideal, and i don't like the idea really but nothing against it.
I don't contradict myself - the CU was effectively outside, although protected from direct rainfall, and no MCB's or RCD's tripped and the DNO fuse didn't blow, so the CU seemed quite happy in a damp environment. Not that I'd put it there out of choice. Even I'm not that gash!
Can see what you're saying as nothing tripped out ect...
Still, even though the CU seemed happy, it wasn't.
was the CU containment not IP44 rated?
Why wasn't it happy then? The CU may have been IP44, but as the cables entered through the back and this was against effectively soggy cardboard I think the rating ended up IP bugger-all.
Apart from damp and condensation, there's the problem of the supply not having RCD protection.
Stroppy, if the CU was so happy, then I assume it's still in place?
There's been a thread similar to this before, except it was going to be a wet room as opposed to a bathroom. As others have said, if it's out of the zones then box it into a cupboard. If it used to be the old kitchen then I'm guessing it's going to be a fair sized bathroom. As long as the DBS not under the bath or anything lol
BS7671 still requires crcuits of a location containg a bath or shower to be RCD protected.
Being outside of the zones, is not outside of the location, despite what Part P says.
