J
j_kent_uk
Hi All,
New to this so thank you in advance for being patience with me.
I am based in Southeast London, I am looking to have my old fuse box changed to 17th edition consumer unit, does anyone know how much this job cost nowaday? Got a quote but seems quite expensive in my opinion(?). Can anyone help?
John
What were you quoted?
£350 for the board - this includes tests of all the circuits.
£100 ish for the bonding
£35+ for tails if required
PLUS fault finding if the testing flushes out issues.
Make sure the person is registered for Part P
Lots of variables when carrying out this type of job. Why not get 3 or 4 more quotes and see if that gives you a better idea.
I have charged anywhere from £350 - £700 for this type of job, depends how many issues there are with the wiring, how many circuits there are etc. Impossible to quote without seeing the job and doing a few tests.
oh btw, the fuse box is in the hallway, with no cabinet and the meter is in the porch, all very accessible.
the quote is in line with Murdoch's suggestion (£300 for the CU and £100 for earth bond cable to water mains) so I am wrong in thinking that it is expensive. Didn't realise how expensive these thing nowadays. Only last year I've heard to change a consumer unit is around £250, all in. My bad :(
I'd say that was on the low side but I've not seen the job.
Does the quote confirm Part P/LABC notification?
Part P registered electrician in SE London happy to change a board and install bonding for around £400. Sounds fair to me. You will get an Electrical installation Certificate, and it will be notified to your local Building Control.
