Increased to 75% in 2010 I believe.
Pg 123 of this doc for reference http://www.planningportal.gov.uk/uploads/br/domestic_building_compliance_guide_2010.pdf
Glancing through Approved Doc L1A it does seem as though some 'trading' between energy efficiency measures might be allowed.
As I understand it you have to fit 75% energy efficient lighting, but no longer need to use specific EE fittings, that way the customer is free to change stuff later if they want to.
Edit: Actually, it appears to be a combination of the two: You can either fit dedicated fittings that only take energy efficient lighting, or you can fit standard fittings supplied with low energy lamps.
