Discuss Part L... Low energy lighting in the UK Electrical Forum area at ElectriciansForums.net
Increased to 75% in 2010 I believe.
Pg 123 of this doc for reference http://www.planningportal.gov.uk/uploads/br/domestic_building_compliance_guide_2010.pdf
Glancing through Approved Doc L1A it does seem as though some 'trading' between energy efficiency measures might be allowed.
As I understand it you have to fit 75% energy efficient lighting, but no longer need to use specific EE fittings, that way the customer is free to change stuff later if they want to.
Edit: Actually, it appears to be a combination of the two: You can either fit dedicated fittings that only take energy efficient lighting, or you can fit standard fittings supplied with low energy lamps.
Reply to Part L... Low energy lighting in the UK Electrical Forum area at ElectriciansForums.net
