J
jimmy b
went to look at a friends fused light switch and double plug socket. There is no power goin to either. i have no idea y? the fuse in the switch has been changed but no joy. i have a voltage pen tester and calling to that there is no voltage going to both. all other sockets on the ring work.????????
there's a fault! you need to call an electrician.
Just read them now Murdoch.
With all due respect Jimmy, you can't keep coming on here everytime you go to a job and you don't have a clue whats going on. As regards to the 'homework' questions on the other thread you started....i think we can safely safe that this isn't the case is it.
Hope you find the problem and correct it safely.
not had that pleasure, murdoch. just thought he was a DIYer with a voltsick.
What amused me was that the previous posted slated the forum and he was saying he wasn't coming back. lol
Good help the clients of these half wits.
Yeah i read that, was only a week or 2 ago wasn't it!
Getting stuck once a week/fortnight, can't be good lol. Makes me wonder what sort of tosh they have to tell the client at the time 'durr it doesn't work because the thingys broken', and how an earth do they not feel embarrassed.
I am not a spark yet, I was just looking at a problem for a friend. Really u lot ate a bunch of helmets, wot is the point in this site if all people do is put others down
Ok matey. what tests did you conduct and what were your findings?
well, you should rephrase your posts. might be better to put this type of post in the trainees section. there it's expected that you are learning and help would be more forthcoming. for what it;s worth, you need first to get an approved voltage tester. then work logically from where you have no supply, back to where you have it. then you most probably will have tracked down the fault. if it's not a broken/poor connection/fuse/mcb, then it's likely to be a damaged cable.
jimmy, it is an Electricians forum, i.e a forum for electricians. Not a DIY forum which may be more useful to you. If you can`t find the problem you really should not be tinkering with something you don`t understand.
As I said I am not a sparks and do only have a volt stick, but I took switch and socket off wall, use the volt stick and there was no voltage.
In which case all I can suggest is that you tell your friends to call an electrician as a volt stick isn't likely to help with professional fault finding!
