S
Sparky28
Hi all, quick question re part p....
Been asked to replace shower, install extractor fan, and spur for electric rad.
Customer has asked for a certificate to cover the work.
Firstly, do you need part p to do this and can you self sign an Eic to cover work?
Cheers chaps
Hi welchy, excuse my ignorance, I thought it was only notifiable if it was a new install??
Maybe and yes!
There you go 2 different answers.
Where is the fan and where is the spur?
- - - Updated - - -
better read up on the rules are you are way off the mark
install extractor fan, and spur for rad
Cheers chaps
That would be new work, the shower replacement wouldn't strictly be notifiable, but you should really still issue a minor works showing the existing circuit is adequate for the new shower
Thanks Murdoch, I am out of touch, my main job is working on trains.
Was going to spur off the ring to supply feed for rad and tap off lighting circuit to install ext fan.
If you need to be part p I won't do it.
In what location are these changes being made?
What about bonding?
What about RCD's?
Murdoch, in a bathroom, supply for shower is from a one way c/u re wirable fuses.
Was going to change this for a rcd shower c/u.
Re bonding the water pipes have been bonded but are being removed so was going to use that.
murdoch, in a bathroom, supply for shower is from a one way c/u re wirable fuses.
re bonding the water pipes have been bonded but are being removed so was going to use that.
[/b]
sparky 28 has not been back,so the quote above has not been explained,its time now for a guessing game
My attempt.just let me have one more read--------------Ok, here I go
I still have no idea
How can utter confusion be manufactured by so few words
