any good solutions for clipping them to brick? got 20% success rate hammering them into walls, will prefer something wall-plug based :)
swa with cleats,plugs and screws
if thats your main concern
(or use fp200 with clips (not used them the ones you screw in) and use plugs in wall as well)
Visiting friends in Leicester garden / outside lv lighting cables held up with "No Nails" they said it works great as its been there for a few years. Simples, who needs to pay a sparks?
and who says FP200 is good for outside installation? if you use red FP200, it will soon go pink, FFS, and who wants that?
Well I ran a T&E up to my shed 20 mtrs away from my house 20 years ago clipped to a fence and it is still working and looks fine, I haven't tested it in 20 years though, apart from a pond supply, a weatherproof socket and 2 fluorescent lights it has not got much load on it, Biff is this okay?
i did.
and the cable manufacturers themselves.
and anything coloured red fades quickly in strong UV , doesnt mean its detrimental in any way.
and why would anyone use red cable surface clipped outside in an domestic setting ?
Because its surface and its less than 50mm, if it was more than 50mm from surface then it wouldn't require rcd @ glennspark
I'm in agreement with glennspark here. You seem to be under the impression that a cable outdoors requres RCD protection.
You will need RCD protection for socket outlets, but not for surface run cable (or SWA using any installation method).
Unless it's a TT supply.
