G
Guest55
any good solutions for clipping them to brick? got 20% success rate hammering them into walls, will prefer something wall-plug based![]()
for fp200 ?
use pvc covered P clips & standard red wall plugs.
eh?...Because its surface and its less than 50mm, if it was more than 50mm from surface then it wouldn't require rcd @ glennspark
someone in brighton perhaps...and who says FP200 is good for outside installation? if you use red FP200, it will soon go pink, FFS, and who wants that?
and who says FP200 is good for outside installation? if you use red FP200, it will soon go pink, FFS, and who wants that? Barbie:candycane2:
Wow i never knew these existed, the hours of my life i've wastedPin-plugs55PP - TOWER - PIN PLUG, BX100 | Farnell United Kingdom Just make sure you use a 5.0mm drill bit, not 5.5!
better than spadework eh Rob?...lol...Wow i never knew these existed, the hours of my life i've wasted![]()
