S
Slinky
An assessor said it was ok to work on a live consumer unit with an exposed busbar ?
Testing an RCD/RCBO is always a 3 lead test. If your carrying out your assessment on a mock install you may have a pendant and flex, unscrew the rose and just test with relevent leads on line,neutral and earth and start your test,rememeber it may be fiddly but DO NOT remove those covers on the tips of your test leads or your assessor may be reaching for GS38.
Ever wondered why you're not an assessor?On an assement ? id fail you without you getting your `croc clips out`
can some one explain in detail, laymans terms please, how to do an rcd test on a rcbo board at the board (im not talking about socket circuits)
i have an assesment soon and want to get this part right, will it be ok to rcd test at the board or should i do at the lighting point ?
if im to test at board do i connect to terminals on rcbo or do i connect to nuteral flex on rcbo, do i conecct to earth flex on rcbo or earth bar, or as ive been told do i connect tails in to terminals to avoid no trip issues due to direct contact. can some one help me on this ?
Ok,so lets take an RCBO as they are the trend these days,how would you get your probe into that deep set line or neutrel screw ?
I have some probes with very thin tipsOk,so lets take an RCBO as they are the trend these days,how would you get your probe into that deep set line or neutrel screw ?
Both my Metrel and Fluke meters will only test an RCD/RCBO with 3 leads,it wont allow the test without them,yes i could leave the N lead hanging there.
