Testing an RCD/RCBO is always a 3 lead test. If your carrying out your assessment on a mock install you may have a pendant and flex, unscrew the rose and just test with relevent leads on line,neutral and earth and start your test,rememeber it may be fiddly but DO NOT remove those covers on the tips of your test leads or your assessor may be reaching for GS38.
Not always it depends what meter you are using. So you think it is safer to climb a ladder, open a rose which is LIVE and fiddle to get the probes into those tiny terminals hold them there and press a test button. Then take the probes off go down the ladder, reset device and repeat a further 3 times.
- - - Updated - - -
On an assement ? id fail you without you getting your `croc clips out`
Ever wondered why you're not an assessor?
You have to know how to carry out the tests correctly to assess someone on how they do it. Maybe a read of the relevant books on testing would help you
Dont get me wrong some makes of consumer units do have a busbar that is out of touch,crabtree to name one but most of the common makes have an exposed busbar.
can some one explain in detail, laymans terms please, how to do an rcd test on a rcbo board at the board (im not talking about socket circuits)
i have an assesment soon and want to get this part right, will it be ok to rcd test at the board or should i do at the lighting point ?
if im to test at board do i connect to terminals on rcbo or do i connect to nuteral flex on rcbo, do i conecct to earth flex on rcbo or earth bar, or as ive been told do i connect tails in to terminals to avoid no trip issues due to direct contact. can some one help me on this ?
test on outgoing terminals on rcbo.
bassically L out on rcbo, N bar and E bar in ccu
simples
this is the same as testing a socket with socket plug for tester
Ok,so lets take an RCBO as they are the trend these days,how would you get your probe into that deep set line or neutrel screw ?
What a load of rubbish, you can test your RCD/rcbo with just 2 leads, live and earth.
or do the RCD's you instal have to have a fault on live, earth AND neutral before they work?
With a long probe. Simple!
i could tell you plenty of other ways, but not suitable on your assessment
Both my Metrel and Fluke meters will only test an RCD/RCBO with 3 leads,it wont allow the test without them,yes i could leave the N lead hanging there.
Somehow, I think slinky ain't gonna last that long on here, 8 posts and he is telling us all how to do our jobs (wrongly)
They dont have to be thin,just long.Ive seen lads use a croc clip with a short piece of 6mm but on an assessment would you chance that ?
So if the N lead is just hanging there is this still a 3 lead test, (as you said it had to be) or just a 2 lead test?
Maybe he'll realise that if one says this and everyone else says that, that chances are everyone else is right.
People have always had some queer ideas about testing
It may be wrong to you but it`s right for an assessment.It`s like taking a driving test,10 o`clock 2 o`clock then once you pass its slip sliding away.
