They dont have to be thin,just long.Ive seen lads use a croc clip with a short piece of 6mm but on an assessment would you chance that ?
For crying out loud man, we are supposed to be trained professionals! We are supposed to know how to carry out live tests that are required by BS7671
I would use that N lead,it`s there,use it, bet your the `it doesn`t need the earth conductor so cut it off` kind.
Cosmic
It may be wrong to you but it`s right for an assessment.It`s like taking a driving test,10 o`clock 2 o`clock then once you pass its slip sliding away.
Mate, before you come on spouting about what's right or wrong maybe you should learn how to do things properly. Assessors are not electrical gods. Just like everyone else they can get things wrong
I don't understand, earth croc to earth, neutral croc to correct outgoing neutral, command probe on live, still got one hand free to reset Rcd?!
Cosmic
Sorry mate, I think you are out of your league, so now you are just trying to make stupid comments.
Where on this forum have a EVER stated that I cut the earth conductor off,
best you quit now before you get shot down
Slinky you really have a lot to learn. Any decent MFT will have a set of long narrow probes which will allow you to test any RCBO. These are a must especially if you need to test through test points in panels etc.
can some one explain in detail, laymans terms please, how to do an rcd test on a rcbo board at the board (im not talking about socket circuits)
i have an assesment soon and want to get this part right, will it be ok to rcd test at the board or should i do at the lighting point ?
if im to test at board do i connect to terminals on rcbo or do i connect to nuteral flex on rcbo, do i conecct to earth flex on rcbo or earth bar, or as ive been told do i connect tails in to terminals to avoid no trip issues due to direct contact. can some one help me on this ?
Just do it right and do it safely,don`t give your assessor reason to fail you,it makes him money on a re visit.Once you have passed then by all means do it how these two loons describe it`s your choice and it`s your fingers.Good luck:wink:
Sorry badwolf, but slinky would fail u on your assessment, before you got your croc clips out.
Sintra i just dont ever work in a live DB/CU,it`s my life at risk and ive been doing this since 91 and `touch wood,your head` ive never had a shock,if you prefer to work on a live DB/CU then so be it.
Right mate I'm not here to be insulted by you have a little break for a couple of weeks and perhaps you will learn a little respect. :waving:
