T
trev
Back to the subject matter. Paddy, the right answers are contained in your thread. None of them were given by Slinky.
No more than 4mm, recommended 2mmacording to gs38 you are allowed 3mm exposed on tip.
as long as there is no more than 3mm or so showing i think they would be fine.
(don't quote me on it memory is a little hazzy)
Oh dear. Enjoy the rest of your time here Slinky. I'm betting it won't be long
My tester requires 3leads before it allows me to testWhat a load of rubbish, you can test your RCD/rcbo with just 2 leads, live and earth.
or do the RCD's you instal have to have a fault on live, earth AND neutral before they work?
Slinky you really have a lot to learn. Any decent MFT will have a set of long narrow probes which will allow you to test any RCBO. These are a must especially if you need to test through test points in panels etc.
Huh I missed all the fun here then?
ok trev so you recomend testing at board, im reading all differant correct ways to do this rcbo rcd test (not including slinkys way) so am i correct to crock to earth bar / probe ,live terminal /is it okay to connect to nuteral bar or do i need to get in to the nuteral terminal ?
by the way my tester is a kewtech 65 with all leads
