ok trev so you recomend testing at board, im reading all differant correct ways to do this rcbo rcd test (not including slinkys way) so am i correct to crock to earth bar / probe ,live terminal /is it okay to connect to nuteral bar or do i need to get in to the nuteral terminal ?
by the way my tester is a kewtech 65 with all leads
I'd not put the neutral croc on the bar mate, I'd use the terminal but in a nutshell that's it
ok thanks for that, but what do you do if you come acrsoss rcbos that dont trip due to direct contact issues ? havent came across thease myself but im told there out there
cheers
what do you do if you come across the rcbos that some say !!! dont trip due to direct contact
I've not found any either, they shouldn't exist as they're not monitoring where the fault is. Just that the fault exists.
You could always try a remote point to make sure though
Paddy .......... I can't belive that you have at least two threads running on this very same subject. This thread has run to 65 replies spread over 5 pages and still you're asking the same question !!
I have to ask: what would you do if I showed you 6 shovels leaning against a wall and told you to take your pick?
no what you need to do is go away! if want to start a 100 threads what the fk as it got to do with you ! are you sitting there with ya mars dress on you fkn old woman
It might not have a lot to do with him Paddy but the mods would take a dim view of it, just like they will of you throwing abuse at a well respected member for no good reason.
Wind your neck in a bit, knowing Geordie it won't have been meant in the way you're taking it.
I gave him the answer in post #60.
well i beg to differ as it was read as a dig towards me,no need for his comments to start ! as maybe no need for mine, apoligys for that, but am not gonna take comment like that lightly as he will proberly mine .......
OK ..... the sad fact is Paddy that most of the lads here have given you very sound advice and told you time and again how to do this yet you keep coming back asking the very same question time and again. It's as if you're not bothering to read what people are telling you - never mind understanding it - and there comes a point where I have to wonder if you've chosen the right career path, and when this is gently suggested to you, you come across as a typical stroppy kid ... all attitude and ignorance.
It will get you precisely nowhere bonny lad, so drop it !!
Sorry to tell you Paddy, if you come on here with that attitude, you will quickly learn - when you ask for advice you will not get it. There are some kn*bs on here, they very quickly get weeded out, and get the same back as what they give
dont be one of them, and you will find this forum helpful. Stay on the idiot path and you will struggle to find out anything. And personally I think every spark needs advice sometime. Myself included.
