E
EWebster
Does anyone know of any tools/tricks to make a downlight hole larger neatly and quickly? Using a larger cutter just leaves a mess!
Cheers
Euan
Make a template with ply, plasterboard or something similar the size of your new hole, hold it firmly over the existing hole, (it's better if you have another pair of hands for this) and drill.
Good plan. I'll make a load out of plasterboard and do that, although lining it up with the original hole could be tricky!
If you're lucky you'll have the sort of holesaw mandrel that has enough thread to take two blades, if so then fitting the original sized blade inside the new one allows it to act like a pilot drill would, stopping the new blade from careering across the ceiling.
Thats the best way i know aswell
You could also try a piece of wood pushed up through the hole which extends past the hole by 2 or 3 inch either side, pull down on wood and screw through ceiling into wood at either end then use wood to drill pilot hole and enlargen hole.
Although padsaw is quicker this is good for lat/plaster ceilings where a padsaw can do more damage with lats snagging and snapping.
Down side is you need to patch up screw holes that held the wood in place after but this isnt a issue if deco follows.
There is a machine available for your drill which has a plastic dome on it with foam around the edge and an adjustable blade to cut the hole. never used one but some people swear by them....or was that swear at them..LOL
The OOPS arbor/holesaw setup is available in this country - just contact a Starret wholesaler or distributor.
Looks like it would fare point, but with the dust catcher and arbor it kills two birds with one stone, cuts the bigger hole and stops mess being made.
