M
moose
Nothing Hard just a fault that could occur.
At DB the RCD seems not to function pressing the test button also notice while pressing the button it changes the LEDs on the Plugin tester, which is plugged into a local socket, the Plugin tester lights are saying Line to Earth reverse also notice while turning off other circuits other changes example
The Plugin Tester Changes LEDs when the Lighting Circuits are turned off at fuse board?....
1) 246 Volts L+E
2) 200 Volts L+N
3) 0 Volts N+E
1) 246 Volts L+E
2) 200 Volts L+N
3) 0 Volts N+E
