S
sweetcheeks82
Hi, After a formal visual does the equipment get a pass sticker or is that only after actual testing?
if you think it's safe for continued use, then a pass sticker is appropriate. on the test cert. you could put a comment. end of the day, it's your call based on your competence.
You get blue sticks for a visual. Have some greens in my hand and on the back if the pack it shows the range of stickers and log books (kewtech)
visual inspection stickers are on ebay at good prices, theres also other stickers such as the microwave labels and plug top lablels etc....
after i do the visual inpsection would i leave the green pass label on until the next test date. so it has both?
equipment has passed electrical test and has green pass sticker.
Then later it passed visual inpsection, would i leave the green pass label on until the next test date. so it has both?
thanks​
Following a formal visual inspection, if a sticker was required at this point, i'd issue a visual inspection only sticker - not a pass label.
This all sounds to be getting a bit out of hand - there is no legal requirement to PAT test at all, but it seems to be providing a lot of people with jobs. Every appliance should be visually inspected before each use, then "PAT tested" every year or whatever, which could just involve a visual inspection or could involve earth continuity, IR, run leakage tests depending on the construction.
Going around "formally visually inspecting" every appliance in the interim period between testing just sounds like busywork. Either carry out the appropriate tests or don't.
A quick look online reveals there are loads of different kinds of "passed visual inspection" labels, most likely because people are willing to buy them and not because going around just visually inspecting everything is officially recognised.
As if a 2 day PAT testing course weren't short enough, now there are 'companies' who want to dumb it down even more and get businesses to pay them to have a look at an appliance and slap a sticker on it.
"Well we could test it for you for £1.50 or have a quick look at it for 50p."
"Do I get a sticker for 50p?"
"Yes"
"That one then."
What i meant was if an appliance has passed the electrical test and the next test is visual inspection, do i remove and replace green pass label with visual (blue) one?
No-one will know its passed electrical test if green pass sticker has gone....
What I'm saying is I don't think there should be two separate tests - you do the testing and put a test sticker on, then the user should do a visual (or rather 'all senses except taste' inspection) before they use it, without having to put any more stickers on the appliance.
How come you're going around doing visual-only inspections?
In my opinion you would conduct a visual inspection before you even consider testing an appliance with a PAT tester. If there are any visual defects that you are not going to repair, cut the plug off and take the appliance out of use and record your findings.
If you have conducted a visual inspection and you are happy with the appliance, I would then proceed to test it applicably and issue a green pass sticker which would cover both your visual assesment and your electronic tests.
You can purchase visual pass stickers - personally I'd use these for items of equipment that you can't PAT test (laptop chargers, phone charges etc etc)....
sweetcheeks82,
KAS1,
