Drill the hole a little too small, push them in then silicon from behind, a bit labour intensive ;) I would also suggest a false ceiling panel, so you can do all the drilling and fixing on the ground, you can then still get to all the light boxes, as you leave the sides of the false panel open :)
What pretty pattern on the ceiling is he after? Most people prefer star constellations. You could let your imagination run wild on this one. :smile5:
Denmans do them , £173.84 order code SS124CBL 552407 for Blue / White Twinkle or SS124CBLK 552408 for Black / White Twinkle . They have 112 points of light and a 2M length on the strands .
This is one that I have put in my daughters room , they are easy to fit as all you need to do is drill a hole for the little plastic adaptor that fits in this and then push the fibre strand into this from above . Just be careful not to group them together to much .
This is one that I have put in my daughters room , they are easy to fit as all you need to do is drill a hole for the little plastic adaptor that fits in this and the push the fibre strand into this from above . Just be careful not to group them together to much .
Thanks mate
done the ends of optics go into adapters/fittings etc
no, nothing, just run the cables (fibre optics) into position, leave hanging through ceiling, if its positioned close to transformer there will be a lot hanging and further away..... then when ceiling is complete just cut them flush with the ceiling. that's it, fibre optics.
look on ebay there are plenty kits to choose FIBRE OPTIC DIY STAR CEILING KIT 16W COLOUR MODEL, FREE DRILL BIT, FREE SILICONE
