G
GPack
Just a quick one. When adding up all the MCBs in the consumer unit and applying diversity I work out the design current as 101.5A. This is not a large house. A 10.2kW electric oven, 7.2kWshower, 3kW boiler, ring final circuit, 2 x lighting circuit etc. If it were at the design stage I take it the DNO would have to provide a 125A fuse. Based on the fact that most fuses I see at the cut out are 60A-100A, are the providers using different rules of diversity to the OSG?
