T
threephase2014
Hi everyone,
I'm in the process of buying my first tester.
I've been able to have a play with a couple, the Fluke 1651B Multifunction Installation Tester | Multifunction Tester and the Metrel MI3125E Multifunction Tester.
Personally I prefer the Fluke tester, I found it more straight forward to use. I was just wondering what other people thought. Is it worth spending that little bit more to get a tester with more functions or is there a better one out there for the same price?
Thoughts anyone?
Thanks.
It's all about what you are used to and what features you want. I have the Megger 1720 and like it for the auto RCD and the 2 wire no trip earth loop. I have used the fluke testers and find them ok but prefer megger
Hi everyone,
Thoughts anyone?
Thanks.
Out of the two you mention I prefer the Fluke. Upgrade to 1652 for phase rotation and auto RCD. Might also have ramp on that model but cant remember.
I have 1720 also, recently replaced my ageing 1502 with it. Do you find 2 wire Zs gives very high readings, like if you did 3 wire Zs and socket it would give 0.60 ohms and 2 wire the same socket (just for curiosity) and it is 1.10 ohms. I thought it would be great for lighting circuits but the readings are so unrealistic.
I find the 2 wire tests to give slightly higher readings but not as high as you say
threephase2014,
sparkymalarky,
