I am also quite proficient in swahili (beginner) and quite comfortable with turkish,.....and am looking at BSL courses, if that helps you sleep any better tonight.:punk:
It is okay Fella, I can see your English has improved enough to actually be readable now, English will be fine :yawn:
I take it time has elapsed on the patent for the blade runner now then if CK are making that copy now then?
I have got a blade runner and it is good for the cable sizes it fits properly (not the smallest sizes or anything big)
The apprentice got a bit marked when I wouldn't let them use it until they had learned to do it properly first.
To answer your question, I wouldn't bother with that tool, I would use a hacksaw, if your worried about making the armoured square and neat put some inulation tape around the cable before cutting it so you have a guide to follow.
ah yes!!...my first attempt at college went wonky,......mr teacher man suggested the insulation tape idea, it massivly helped,..as for the tool,....im a ---- for gadgets!........:punk:
appreciate everyones input.
So are you going to waste you money on a fancy gadget?
if it helped cut time down in a big way, i deffo would,...as it appears not to,....probably not,....thats why i ask opinions of them in the know,......you lot :punk:
I've watched people with these gadgets and personally wouldn't waste money on one which isn't made of steel or with a blade that lasts longer than these gimmicky gadgets
stick to the hacksaw because its simple to do and you'll always be able to buy one cheaply anywhere but I doubt you can say that about the ck or kewtech
I think they're slower anyway!
go for reliability everytime!
I find eclipse junior hacksaws to be very good and they're about 2 quid had mine for years done hundreds and hundreds of swa's no problems
awwww hacksaws,.......
.....i had a top little hacksaw (i think bacho or ck ??))....anyway, it **strangly** went walkies from my tool box when a load of our eastern european cousins were in the warehouse one day,....along with a lot of other kit,....
.....confront them,...you just get the shrug and stare,....
...universal meaning,.....suddenly "no understand "
back to revision dudes and dudetts,.......elec science / principals exam in a few days..
laters....:punk:
..spark2b
Get yourself a piece of scrap SWA and just practice using a hacksaw on the armour.
Use any junior frame but always use Eclipse blades.
Tried one and didnt like it (was like a pipe cutter with a small section of junior hacksaw blade instead of a roller) my workmate got one at the same time and loves it tho it goes through blades quickly. May be I didnt give it a chance as I find the hacksaw method easy and cheap. Mine was a kewtec one I think not ck.
Found a video of the ck in use looks more robust than the kewtec https://www.youtube.com/watch?v=lcv6tH2wEEE this may help you decide
