G
gutterball
Hi anybody use these? I put 8 down-lights in a hall and stairway about 18 months ago. (customer supplied lamps and fittings from amazon) 3 of them have now failed and i was wondering if it was poor quality led's or a bad batch. I normally use led hut ones or megaman from the wholesalers.
had the same with kosnic. 2 failures in 12 months on an install of 12.. always use smd's from convertabulb now. had 1 fail out of about 200.
Kosnics are total rubbish
Best LED lamp i have come across and use is the MEGAMAN MODO 4.5w
Fitted 100's over the past 2 years and had NONE fail at all
we use them from time to time at work along with osram.
at home im using lumilife led's they have been in a while and going strong (had a couple voltage spikes here and the odd power cut and no issue)
