Would a load register as something like 0.06 Meg ohm on a circuit between N - E ( something like an unfused spur with the fuse removed? or is it just wishful thinking
I think you need to elaborate as how you have achieved this reading and the purpose of the test
Purpose is curiosity of my own electrical installation, and why i would have almost a dead short on N-E but with no RCD tripping unless it was a load
My flat has a circuit in it that tests as follows when live cpc and neutral are disconnected from the CU @ 250 volts
ZS 0.45
L-E >200 megohm
L-N >200 megohm
E-N 0.006 megohm
If it’s just the circuit you’re testing, N-E should be clear. Any load, even a neon light, would be between L-N
What is on this circuit?
Is everything unplugged if it’s sockets?
Is the polarity correct at each point on the circuit?
What are the readings at other points on the circuit?
If it's a radial circuit e.g. cooker/shower/maybe immersion then have you tried turning the isolator off near the load?
I'm having a stab in the dark that this is a heating element.
I have seen this with an old RCD socket - it had something like 50k to E as a means to trip out in the event that neutral is open or swapped.
But it could be some faulty cable of course, which is more worrying. You need to see if any loads were still connected during the test as there was only SP isolation on them.
60KΩ isn't going to be a design load for an appliance, do the maths and that's an Ib of 3.8mA which is daft. It could though be a Neon?
agreed, I was wondering if it was a element deteriorating N to E as 3.8ma leakage seemed plausible.
I should be patient and wait and see what the circuit is!
London
United Kingdom
Other
If other, please explain
School premisis
0.06 meg Ohm could it be a load
Tetris1985,
oscar21,
