They have a fused isolator 60a next to meterMeter tails buried in walls at a depth of less than 50mm from the surface require additional protection
How is that going to protect someone who puts a nail though the buried live tail.They have a fused isolator 60a next to meter
Rcd main switch instead then?How is that going to protect someone who puts a nail though the buried live tail.
You would need to treat it the same as twin and earth buried in a wall <50mm deep.Rcd main switch instead then?
Ok thank you brother, appreciate the knowledge! Can only find 63a rcd main switch garage boards which I’ll just have to use and not use the spare ways. I might have to de rate it down to 40a as 63a will be to much.You would need to treat it the same as twin and earth buried in a wall <50mm deep.
Just leave it as it is and change the consumer unit. Lack of additional RCD protection for this is generally a C3 on an EICR. It is ridiculous to put a 30ma RCD at the source.Rcd main switch instead then?
I’ve changed the board today. All up to date now. Don’t think I’ll need the rcd instead of the fuse at source then?Just leave it as it is and change the consumer unit. Lack of additional RCD protection for this is generally a C3 on an EICR. It is ridiculous to put a 30ma RCD at the source.
Napit codebreakers, for instance, say a C2.I’ve changed the board today. All up to date now. Don’t think I’ll need the rcd instead of the fuse at source then?
No it is pointless discussing it.I’ve changed the board today. All up to date now. Don’t think I’ll need the rcd instead of the fuse at source then?
Did you LIM this on the EICR? I would at least do that to cover yourselfI’ve changed the board today. All up to date now. Don’t think I’ll need the rcd instead of the fuse at source then?
