All this time and hassle to save money on just getting an electrician in to design/install/test the job properly.
Thanks for that. The builder and I have managed to get the cable in today. It's a 25mm swa cable and it goes behind a stud wall and then up into the ceiling and then back down into the room where the CU is situated. In this case will the miniature circuit breaker not suffice? Thanks
Hopefully you've left plenty of working room for the electrician to work on the cable an dfit the correct glands to the end of it. You can't just leave an SWA that size sticking out of a stud wall and expect someone to be able to terminate it into the back of an enclosure.
Building advice,
davesparks,
