B
Building advice
By the time they've gone up walls and through ceilings they will be this long
What happens if he gets things badly wrong and injures/kills himself or someone else, or a fire results in the meantime? Whose insurance policy covers the liability? Is your home insurance still valid if you employ a non-electrician to carry out a CU replacement/move, which is notifiable to building control? What/when is "the end" in this context?He is not a qualified electrician and instead gets his work certified at the end.
Ask your electrician to order through the wholesaler, be expected to get little change from £100Thankyou for that baldelectrician. It looks a lot smaller. Where can these be purchased from? That site doesn't have prices? Thanks
How is your electrician going to inspect this cable? From what you have described, much of it is concealed. It would have been a better idea to assist your electrician in pulling it through, rather than the builder.Thanks for that. The builder and I have managed to get the cable in today. It's a 25mm swa cable and it goes behind a stud wall and then up into the ceiling and then back down into the room where the CU is situated. In this case will the miniature circuit breaker not suffice? Thanks
