Discuss 100amp Isolator switch required in the UK Electrical Forum area at ElectriciansForums.net
If the cables to the new CU position are to be concealed in any walls, then it’s very likely they will need RCD protection.
If however they are just going to run up the surface of the wall into the ceiling and along to drop down into the new CU, RCD protection will not be needed.
Thanks for that. The builder and I have managed to get the cable in today. It's a 25mm swa cable and it goes behind a stud wall and then up into the ceiling and then back down into the room where the CU is situated. In this case will the miniature circuit breaker not suffice? Thanks
How is your electrician going to inspect this cable? From what you have described, much of it is concealed. It would have been a better idea to assist your electrician in pulling it through, rather than the builder.
All this time and hassle to save money on just getting an electrician in to design/install/test the job properly.
Hopefully you've left plenty of working room for the electrician to work on the cable an dfit the correct glands to the end of it. You can't just leave an SWA that size sticking out of a stud wall and expect someone to be able to terminate it into the back of an enclosure.
Reply to 100amp Isolator switch required in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
I haven't seen a lot of discussion on this subject and have questions pertaining to isolation where TN earthing is present and any peculiarites...
Hi I have a customer who has a kiosk with 100 amp cut out fuse supplied from UK power, he needs to bring the power 178 meters to his house, He...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
