Discuss 110 vac Generator in the UK Electrical Forum area at ElectriciansForums.net
Evening All,
I have to supply 3 x 110v ac circuits ,lights , sockets , and 20 amp extractor fan, from a 240v ac supply, using c form sockets from a generator. My question is , is there a 25 kva generator out there that has RCD rated and mcb protection for a 6amp , 16 amp , 20 amp and 32 amp circuits.
Cheers
Sparky 63
I'm a bit confused. You say you need to run 110v devices 'from a 240v AC supply'. Can you clarify what you mean? Are you talking about a 3 phase supply that is 240v between phases?
Yep me to, OP are you supplying a building site, and is the 240v ac you are talking about Single phase, or as Marvo has asked?
Evening All,
Cheers
Sparky 63
Just get a 110Volt generator!
Reply to 110 vac Generator in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
I was asked to go and take a look at a generator set up by a marquee company yesterday to do some testing. It was a brand new JCB 65QS with...
The garage is 17 mtrs x 15 mtrs in the UKh The house has a 100 amp supply to the house consumer unit. The garage consumer unit is fed from a...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
