1x32 AMP, 2x16 AMP 5kVA Portable Electrical Transformer
ive always wonder how these can run on a 13amp plug top
in theory 5va is around 40 amps at 110v, hence the 32amp socket (yes not continuous normally around 5-10 mins but even then surely asking for trouble)
how does it work then would of thought is would come with a commando plug
also i dont belive the weight is 15kg if so would think its rubbish as normally weighty = better quality
(im looking for a decent 110v tranny that can run around 3.5kw at 110v safely / decent length of time)
in theory 5va is around 40 amps, hence the 32amp socket (yes not continuous normally around 5-10 mins but even then surely asking for trouble)
Got something in my shed have a look tomoz and update you
i have a 3.3 KVA one on a 13A BS1363 plug. the 13A fuse is fine but if plugged into a 16A circuit (type B MCB) the MCB trips on plug in. obviously inrush, before the inductance is seen.
The 5kVA is a 'tool rating' which in accordance with EN61558 is generally 25% duty cycle, 5 mins on load, 15 mins off load. The 5kVA tool rating corresponds to around 2.75kVA continuous rating, less than 13A allowing for the magnetising current. So if it's a continuous load you want to power, up to the transformer's thermal limit, there's nothing wrong with either the 32A socket or the 13A plug. If you happen to have a 5kVA tool load, which is not unreasonable, then the 13A plug is a bit daft as you say.
I've run little 1kVA trannies overloaded for longer than they should, sit them in big buckets of cold water.
wales
Other
110v tranny
Electrical Tools and Products
Corbs,
pirate,
