Discuss 12V solar powered UV disinfection system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi everyone,
I am currently undergoing a small DIY project to make a solar-powered UV disinfection system.
The 2 loads I have are a small 4LPM 12v DC pump and a 24V 10W UV lamp.
My system consists of a 50W 12V solar panel which is connected to a 3A charge controller, A 12v 14AH battery, a 200W 12v DC to 220V AC inverter and a ballast to regulate the voltage to the UV lamp.
I was wondering if it was viable to run both loads simultaneously and how to do this? My original plan was to connect the DC pump to the load port on the charge controller and the inverter to the battery terminals, however, I am worried if this is feasible especially considering the low current rating of the charge controller.
If this is not feasible how else can I operate both loads simultaneously?
Thank you for your help
Reply to 12V solar powered UV disinfection system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, So I'm replacing a small old off grid with a new 7.5kw off grid, & being poor seek best value for my mppt, after long searches I find this...
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
Hello, So I purchased a Novopal 2000w/4000w(Peak) Pure Sine Wave Inverter DC 12V to 110V/120V. I purchased this so I can hook it up directly to...
Hi - On our small vessel we have a 12v failry powerful motor to run the autopilot, where the power is supplied by the boat's battery bank. On an...
Hello all, I am a Design and Technology student completing my final project of a portable solar-powered esky/mini fridge cooling system, however...
