Discuss 18th edition exam question.. in the UK Electrical Forum area at ElectriciansForums.net
Colin33
Booked in for my 18th edition exam, so I've been doing some mock exams online. Can anyone explain this one? There's me thinking an RCBO protects against over-current and earth fault current?
It does, and IMHO it's a really bad question. I remember that one from my exam and I'm now fairly sure I got it wrong!
I don't have BBB here at home but in the definitions section at the beginning does it have "earth fault current" listed?
It might be that "earth fault current" is more associated with "prospective earth fault current" in the regs, and answer one isn't technically using correct terminology in the mind of whoever wrote the question, in which case answer 4 is the closest.
But it's a definitely a poor question!
Sounds about right to me.
I think it’s just a poorly worded example question and for what it’s worth, I would’ve picked your answer too
I think it's a genuine exam question, one of perhaps a few which the 'experts' have wrong. I can remember a similar situation with the 17th exam, where I stated the obvious answer but it was 'wrong' apparently. Even the course tutor agreed. However, this time I've skipped the course and just booked the exam so I have no tutor to back me up :)
From the BBB: "A residual current operated switching device designed to perform the functions of protection against overload and/or short circuit"
So it doesn't protect against earth fault currents??
The "residual current operated" bit means it detects imbalances between current flowing in and out of it, and any imbalances "switch" it, and therefore that includes any leakage to earth/ fault currents.
So RCBO's are a residual current operated switch that also provide overload protection.
I do believe you had this all correct in your mind before that question threw you!
(Tangent, but the question I got hung up on in exam related to:
463.1.2
"A single-pole switching device shall not be placed in the neutral conductor except for the connection of the control device for lighting circuits as shown in Fig 46.1"
The question was basically " when can you switch the neutral conductor in a lighting circuit" and I was sitting there thinking "never?!"
463.1.2
I'd think the same. But I still can't work out what a 'single pole switching device' (switching neutral only) for control of lighting circuits actually is?
Basically a contactor/relay, because the switching circuit that energises the coil is not connected to the lighting itself, so switching the N of the coil doesn’t leave the lights live. Never used that fact since!
It is a somewhat misleading set of answers as really a RCBO protects against:
  1. Earth currents (well below normal operating levels, let alone fault conditions)
  2. Overload (usually, though fixed loads such an immersion heater may not need it)
  3. Fault (i.e. short circuit style events) which could be L-N or even L-E so also an "earth current".
So the last answer in the multiple choice is actually correct as it is a sub-set of what it does (2 & 3 above). However, as @Mike Johnson points out the a**hole creating it has decided that wants to see 1 & 3 since 2 & 3 are also met by a MCB/fuse where as 1 is not.
Similarly a RCCB meets 1, but not 2 or 3.
Reply to 18th edition exam question.. in the UK Electrical Forum area at ElectriciansForums.net
having failed my first attempt at 18th edition exam, does anyone have any tips and tricks on how to study for the exam? being that there is a...
Hello all Well, been putting it off, but I need to upgrade my 17th edition to the 18th. Not been a practising sparky for over 5 years, but I have...
Does anyone else get emails and phone calls from companies and agencies say we seen your CV and we want you to apply for our job. And when you...
Hi Could someone please help me with how to navigate the 18th edition amendment 2 (Brown) book in the most time efficient way for the exam. I...
Currently doing my 18th edition as its been so long since i did my 17th just clicked on a Video saying DONT WRITE in the BOOK 😲 only in pencil...
