BobTheBuilder65
- Reaction score
- 0
My mother moved into her three bed home in 1960 and it had underfloor heating in the living room. I remember we used it when I was growing up in the 70s but it hasn't been used for probably 30 years. Electric storage heaters were installed to take advantage of the old off-peak electric tariff that preceded economy-7 but now she's got new Sunflow electric heaters around the house that are costing a fortune to run on a standard tariff. The thermostat for the underfloor heating is still on the wall but I won't risk trying it without a safety test first!
With air source heat pumps now able to supply underfloor heating, would it be mad to try to connect this 62 year old system to an air source heat pump and get it working again? Would it even be more cost effective? There is a gas fire in the room as well so next winter we've currently recommended she uses this in preference as cheaper to run and maybe keep the Sunflows at a low base temperature.
Installing radiators for either a gas boiler or an air source heat pump won't happen as too much disruption to my mother of course so that's why I started to think about the old underfloor system!!
Thanks in advance
Thanks in advance
